Geeze
- Joined
- Jul 25, 2015
- Messages
- 2,453
- Reaction score
- 5,798
I have experimented with multiple methods and continue to come back to the table saw. Less tear out - no set up [once the jig is built] just push it to the key, clamp and cut. The dead nutz accurate dado blade set is the Freud Super Dado - less $ than the Forrest but when I stack blades for a 3/4" cut they hit .750" exactly. Everything else needs shims to get right. Next is fixture / key setup - I measure with machinist calipers to get to the right .001". Last is how consistent your 'stroke' through the cutters is - I have an arrow drawn on the fixture to remind me to load it to the left.What method are you using to cut your finger joints? I started using the table saw and sled, but soon found that there's too much slop when you get into wider boards. I've since modded a Harbor Freight dovetail jig just for finger joints. The more I think about it the more I'm justifying a small CNC router, then I can use it for faceplates too.
It's consistent enough that I have about .002" of runout across 14". It worked well enough to do this monstrosity of four planks finger jointed together - that was a llllllooooonnnnngggg day of cutting.
It's been a challenge planning out the face plate so that ALL of the top and side stripes have a flow around the faces sorta like water. To bad I couldn't use the second set - the top to front would have worked but the sides would be a train wreck.
Cut 2" longer to absorb the .040" blade width cuts which has to be compensated for every cut or else FUBAR.
Some of these cuts will require a smaller bandsaw blade.
Posed.
Russ
