WTB: Casters for a vintage Marshall cabinet
Ramhead
I'd like to buy a set of casters that will fit on a vintage '69 Marshall cabinet. I've read that Fender casters will work, maybe some other will fit too. So offer what you have.
I prefer buying from EU if possible.
Thanks!
Dogs of Doom
~~~ Moderator ~~~
Staff Member
yeah... do you have the pop metal bases?
You have a classic/vintage cab. Either get period correct, or use a dolly... I picked up one of these:
which is just a little bigger than a 1960 cab (front to back)...
My castorless cab though, is in a road case & the road case actually holds the bottom of the cab & has nice castors on it. I got it though, just incase. I do have bass cab's w/o castors, so, it works for those as well... $30 :shrug:
neikeel
These fit and work really well in the 60s Marshall cabs with pop-ins, you do not need to use the bases unless the original tubes/cab bottoms are trashed.
If you find a set of originals they will either be trashed and unusable or horrendously expensive.
I have the above on my 3 basketweaves.
All you have to do will be to gently file the brass olives down a little and then polish them selectively to get them to pop in and out with correct resistance both ways.
Personally I don't like the Marshall ones as they have the plastic bosses in the cab bottom which only work if the castor as screwed hard into the plastic.
Ramhead
Thanks, I'll look into these.
BygoneTones
+1 Those penn elcom ones fit perfect. So long as your original sockets are in good condition they will fit straight in. Just file a very small amount off the gold clip, it doesn't take much.
Originals will be expensive.
Smokey77
For a 1969 Marshall cab…. You need the gold painted Homa casters with the pot metal caster sockets…. Those are what she was born with
