Delicieuxz
- Joined
- Nov 2, 2009
- Messages
- 122
- Reaction score
- 56
On a JCM 800 2203 I've just bought, the low-gain input is incredibly quiet compared to the high-gain input. With the master control at 10 and using the preamp control as a volume control, to keep the amp nice and clean, I can play pretty comfortably with the preamp control at 1 - 5. And this contrasts with what seems to be people's normal experience with the low-gain input. If I plug into the high-gain input, with the master at 10 and the preamp at 0.5, the sound is devastatingly loud. To get the same volume from the low-gain input, with the master still at 10, I need to turn up the preamp control to 8 - and then the amp is no longer clear-sounding, but is thick and dark-sounding, being coloured by the preamp control, which I don't want.
Here's a summary from another thread of people's reports about their own JCM 800s:
On my 2203, with the master volume at 10, the high gain input with the preamp volume at 0.8 is comparable to the low gain input with the preamp volume 8. So, I guess the high-gain input is about 10x louder than the low-gain input. And at 8 on the preamp control, through the low-gain input, the preamp section is colouring the sound a lot and making it thick and not crystal clean anymore.
Is there something that could affect the output level of the low-gain input, while not affecting the high-gain input?Because it only has one stage of preamp gain as opposed to high having been cascaded through two.
I'm wondering what could account for the massive difference in volume between the low-gain and high-gain inputs of my amp, when my friend says that 0.5 on the preamp control and 10 on the master, through the low-gain input, is ear-piercingly loud on his 2203, while mine is very far from being that, and while all these other posters also describe a very different experience:
My 2203 is modded a bit, but the low input is pretty much as loud as the high input.......unlike my stock 2204 where the low input is much quieter than the high input?!?You should be able to take the amp to maximum volume with the master cranked and the preamp volume turned up all the way, in both inputs. The difference would be in how much distortion/drive you get. Not in how loud it gets.I have a 2204 from 1987 that sounds fantastic. But the low input is about half as loud as the high input channel. I use a Power Station attenuator and run the high input channel Master and Pre-amp at around 7-8 each. That is sweet spot for the amp where it sounds full and glorious. The low input, which I rarely ever use, stays mostly clean all the way up on both volumes and doesn't put out anywhere near the same power.
