ricksdisconnected
- Joined
- Aug 11, 2019
- Messages
- 15,089
- Reaction score
- 28,118
True. But considering I had a early Phase 90 and D+ with no LED at all....it was an improvement![]()
all nice pedals though indeed
pedals like the Boss DS1 and the Rat are too much distortion for a 800. Get a Klon clone for cheap. That's it.
Welcome.
I'd also recommend the SD-1, but I use the gain knob...
But if that's all you got to choose from, I'd start with the tube screamer.
Theres 2 ways to get a volume lead boost on your amp, install an effects loop or use a foot switchable attenuator. From your list I like the Rat and the Tubescreamer.
SD-1 (Super Overdrive), not DS-1 (Distortion).Do you recommend the original DS-1 or the DS-1 Waza?
It will work but your tone will suffer.And what if i use a EQ but that is always on with a 5-10db cut until i need a boost and the turn it off?
Or would that suck out the signal to the amp?
I have the SD-1 and it will do the clean boost and/or a nice mid gain crunch on my O20H.
Never tried the Waza variant, so I'm not sure of what it's capable of.
I've also never tried a tubes creamer, but as usual, because I keep reading about it here, I ordered a clone (Demon-Fx) on Friday and should have it in about a week...
How many watts is your amp 50 or 100?
The SD-1 is relatively inexpensive at $50 ($35-ish used).Maybe i should try to get my hands on a SD-1 to try it. So many that talk about it.
I want it as a ”always on” pedal for rythm guitar. So if it can push the amp, give some more distortion, well then i’m happy.
But i am going to try the Tubescreamer and the rat tomorrow to see how it feels.
LOL, just spotted my typo.I've also never tried a tubes creamer,
I've heard the SD-1 and Tube Screamer are very similar as a clean boost.
Here's a recent thread by @Guitarjon comparing the two on a DSL50.
DSL50, to boost or not to boost? | MarshallForum.com
I do have a Rat (on loan to my son).
Completely different tone, and not sure how/if it even works as a clean boost.
Perfect! Get a Bad Cat Unleash. This is your solution, read up on it if you're not familiar.It’s a 50watt
JCM 800 Model 2204 i think
Not if you know how to use them.
Gary Moore in his heyday- 2203s and a DS1 on the floor. Jump to 42 seconds.
I have a JCM 800 and now i have some pedals on my radar to push my amp for more distortion. I play fast rythm punk music.
No punk rock or pop or that kind of stuff.
I was thinking that maybe i could even stack 2 pedals for more push into the amp but then it feels like the amp is at max, and i would really like to boost in some way for minor solos or riffs that needs to stand out.
I would use an eq for your boost. Off, the signal goes straight into your amp. Your rhythm sound. On, you can boost the signal a little and also adjust the EQ so it cuts through the mix. Your lead sound.
Just so we know what sound you are looking for what bands are you calling punk.
Through the decades the term "punk" has been used to call many bands that are not truly punk.
Example: Sex Pistols, Fear, Dead Kennedy's, Ramones are what I call punk.
Green Day, Blink 182 are not. That I would call (punk) pop.
I hear you, there are many subgenres to punk music but i
These are 2 bands from sweden that play punk that i like
(No i have NO fx-loop and only 1 channel)
These are the pedals i have to chose from:
Digitech DOD FX40-B
Zvex Super Hard On
ProCo Turbo Rat
Boss DS-1
Catalinbread SFT
Ibanez Tubescreamer (Analogman silver mod)
What do you think would be the best setup for a nice rythmsound with ampdistortion and clarity, but if possible also have to option to boost the tone some DB.
one pedal to drive the amp and one for solo boost
This setup will be for live use.
Kind regards!
