As far as amplifiers go, what's next? I mean, what can be done now? I see amps coming out with built in attenuators and that seems kinda cool. What happened with power scaling? I never had an amp with power scaling. Did it work well?
With speaker IRs, it seems like one doesn't really NEED a built in attenuator as long as you can afford a Captor X or a Suhr reactive loiad or something similar. And pedals can give you reverb and delay and gain.
What can be done that hasn't already been done really well?
The only thing I can think of is using other types of tubes that we don't normally think of in the classic amps we all use. For example, my Monkeymatic amp uses 6973 power tubes. It sounds killer. What other tubes can be used that are still affordable and readily available?
I know Otis amps uses a pair of 6CZ5’s, 6SL7’s and a 5Y3 rectifier tube for his 12 watt amplifier. Those are still available as NOS for around $15 or less. Maybe I should stock up on them...
