Which do you like?
  • Faceplate lined up with top
    Votes: 1 33.3%
  • Faceplate mirrored with top
    Votes: 0 0.0%
  • Faceplate straight up
    Votes: 2 66.7%
  • Total voters
BlueX
Silver Supporting Member
Sweden
I might repeat myself, but it is a real pleasure following this process in all its steps!
One side you can't see anything the other is a fine line.
I'm sure you're the only one noticing that. There's so much else to look at for the rest of us.
Geeze
Now sanded to 220. I decided to mask the boundaries rather than wade through the turd floater occurring in my neck of the woods to go and get art grade brushes.
First rub of the sapphire blue. It looks much more better when it's lacquered.
Russ
Marcomel79
Oslo
You are a true artist Russ. Just stunning. Always look forward to your threads
Geeze
Sapphire blue rub #2.
I decided to lacquer the shell to keep me from tracking blue on the non blue parts as I fit the faceplate.
Last night I also discovered FUBAR #2 - I wanted the top angled jack to be centered on the front faceplate jack. A great plan that was foiled by centering on the rear end of the top jack not the front end. Moving the front jack to the left to center on the top jack is an obvious solution except Marshall's plexi faceplates are 17" wide - at least on the 50 watt and I'm pretty sure they used the same plate on the 100 watt width heads. This would expose at least a 1/4" of steel chassis something I'm not willing to do at this point.
So for this iteration the jacks aren't going to line up unless I do an artful fix and angle the front jack the other way. Hhhmmm...
Russ
BlueX
Sweden
Would off-set design be possible?
Geeze
After contemplating options I decided to use the centered jack face plate as the shell wouldn't work with as much offset as I needed and I would have needed to splice more wood on to the faceplate to make that work - neither appealing options.
Tomorrow the control notch is cut, rough sanded and logo time.
Russ
BlueX
Sweden
I have mixed reactions. Sorry about your disappointment, but at the same time looking forward to see this waving flag being realized.
