ken361
Pete Thorn like those redbase tubesYeah man. Look forward to hearing about it. Haven't tried the 34's.
I put 2 pairs of the Ruby’s in my Dsl40c’s.Pete Thorn like those redbase tubes
Too cool! Good ole Martimus. I still have a couple of his tube business shirts which look cool as shit.
My V1 tube is a BEL 12AX7 Marty turned me on to. I really like it with this amp. I got the RFT AT7 and Mullard AT7 from my source recently. Those buys turned out great with this amp too. Just experimenting. Reading and then pulling the trigger.
Prices are out of my league for NOS 12AX7’s but some of these lesser gained versions can be bought and utilized for good results too.
True. The BEL kinda does what an RFT does in V1 of a Marshall. Shaved some top end yet barks and bites. I've read a few guys referring the BEL to a Mullard in likeness. Wish I had more. One of mine bit it. I just have the one now. And I like it best in this bitey Marshall amp.Marty was always promoting black-plate Ray in V2, but, as you said, it's uneven & he recommended that particular one for PI... 👍...
He said that the BPR was very transparent, so, if you put a stellar tube in V1, it would give you that tone w/o coloration. Like, RFT, if you put that in V2, you will hear RFT from that point on...
Interesting, Steve. I have a Mullard in V1 of mine and a Raytheon BP as PI too!!I found my stash of tubes I got from Marty. I also found where I printed out what he told me they are. I've been using the Raytheon BP in V1, but he said it's a lopsided very high gain tube and he recommended putting it the PI. I don't know if I ever even tried it in the PI before but I put it in there and is sounds great. So then on to V1, I rolled a few and ended up (for now at least) with a NOS BEL India Mullard (by Philips) in V1. Amp sounds pretty awesome right now. Way better than it did with the CP tubes in those slots.
Now to experiment with V2 (hot mod), right now I still have JJs in it..
I also have a NOS Canadian Mullard (by Philips) and a used 1959 Square Getter RCA that I got from Marty.
I have a Dr Z attenuator round here some where. I believe it’s good up to 50 watt amps. Pm if yer interested. I’m not selling but you can use it as long as you want. Otherwise it will continue to gather dust. I used it with my amps a bit. Ran fine.Are any of you guys using an attenuator with your SC? If so which one? I may be looking to get one soon.
I have one, a Weber Minimass 50, I’ve had it about 3 years now, it works great!Are any of you guys using an attenuator with your SC? If so which one? I may be looking to get one soon.
There are some great overdriven tones in these amps when pushing the power amp section, along with the preamp section.
I like the master on 7 or 8, with the preamp around 5 or 6, can’t do that at home, (20 watt mode), without an attenuator.
There are plenty of choices to choose from at all price points, from around $100, (Bugera Ps1, I don’t recommend it), to well over $1000!This is exactly why I'm thinking I might want one.
Good choice! I run the big Weber occasionally and like it...as far as attenuation goes.lolThanks guys!
After your comments I definitely want one. I just feel like I'm missing something by not being able to crank the power section and curiosity got the best of me.
Solar, I appreciate the offer, but I'd rather not borrow.
I looked for a Jet City, but didn't find one. I didn't even look at any others because I'd rather go with something recommended by you guys and since scozz is using it without issue, I just went ahead and ordered a MiniMass direct from Weber.![]()
Master on 7-8 and preamp on 5-6 yields some incredible tones with the SC20!! It allows the guitar volume and tone to then provide the whole pallette of tonal color.100% agree. (Honestly, even on the 5-watt setting, you don't have to use 20 watts, although like you, I also prefer the higher setting.)I have one, a Weber Minimass 50, I’ve had it about 3 years now, it works great!
I use it most of the time, but sometimes, (when my wife’s not home), I’ll bypass it to get the speaker pushing some air.
Attenuators are great for making it possible to crank the volume at home without losing your hearing.
