1956tvmodel
- Joined
- Jan 30, 2009
- Messages
- 153
- Reaction score
- 181
I am selling my Suhr SL67 HandWired 50 Watt Head. The amp is as mint as it gets. No blemishes, scratches or dings anywhere on the amp as you can see from the pictures. Very low hours on the amp. Bought new in 2021. The amp comes with power cable and ships in the original box.
A new one sells for $2595.00 plus tax so your saving over $400 and getting a virtually new amp.
I'll include all the specs and description of this am amp below. If you want any additional pics or have any question please feel free to text or call me.
Here is a link to a video showing a great demo of this amp.
Let me know if your interested.
Thanks
Here are the details on the amp...
The Suhr SL67 amplifiers are no compromise, hand wired, amplifiers built to deliver the complete range of classic British-style tones at any volume. From sparkling cleans to screaming high-gain Variac™* style overdrive tones, the SL Series responds dynamically to every nuance of your playing style and instrument with just a turn of your guitar’s volume control.
Each SL amplifier features hand wired construction, four inputs (Normal and Treble), Low/High power switch, Master Volume control (located on the back panel), and is powered by EL-34 power tubes and three 12AX7 preamp tubes.
VARIAC™* POWER MODE
The three position power switch incorporates a low power Variac™* mode which lowers the amount of voltage available to the amp. This classic mod makes the amp feel much more spongy with a smoother attack and has been the foundation for some of the greatest rock tones of all time. To avoid having to re-bias the amp when switching power modes, SL amplifiers have two internal bias adjustments, one for HI power, the other for LOW.
CUSTOM “PLEXI” OUTPUT TRANSFORMER
Output transformers have a major impact on tone. It’s the bridge between the output section of the amplifier and your speaker cabinet. We’ve spent countless hours listening to different transformers until the spec was finalized for our custom “PLEXI” output transformer. This transformer sounds clear, is dynamic, and lends authoritative authenticity to the amplifier.
MASTER VOLUME CONTROL
Suhr SL amplifiers feature a Post Phase Inverter Master Volume control. This type of master volume control is highly effective at transparently controlling the output of the amp. When the control is at 10, it is completely transparent and out of the circuit. Start turning it down, and the amps volume can be reduced all the way to whisper levels.
POWER SELECT SWITCH
Offers the following three-positions:
OFF: Amplifier's power mains are switched off
HI: On, normal operation
LOW: Changes the SL-67 feel from tight and aggressive to spongy with a smoother attack, excellent for solo playing.
PRESENCE - The Presence control adjusts the amount of high frequencies added to your sound, turning it clockwise will add more cut and sparkle to your tone.
BASS - The Bass control adjusts the low end, turning it clockwise increases the amount of low frequencies in your tone.
MIDDLE - The Middle control adjusts the midrange, turning it clockwise increases the mids, making it fatter. Turning it counterclockwise will reduce the mids and produce a scooped type of sound.
TREBLE - The Treble control adjusts the top end. Turning it clockwise increases the amount of brightness or treble frequencies in your tone.
VOLUME I - Adjusts the overall output level of Channel I.
VOLUME II - Adjusts the overall output level of Channel II.
CHANNEL I INPUT (top) - Has a high sensitivity and voiced brighter than Channel II.
CHANNEL I INPUT (bottom) - Has low sensitivity and offers a slightly warmer tone.
CHANNEL II INPUT (top) - Has high sensitivity and offers a normal/bassier tonal response.
CHANNEL II INPUT (bottom) - Has low sensitivity and a normal/bassier tonal response.
BRIDGING OR JUMPING THE CHANNELS - Bridging or Jumping the channels will unlock a palette of sounds and expand the SL-67's possibilities. Begin by plugging your guitar into the top (high sensitivity) input of Channel I, then run a short instrument patch cable from Channel I's bottom (low sensitivity) input to the top (high sensitivity) input of Channel II, then blend Volume I and Volume II controls to dial in a wealth of new and unique tones.
MASTER VOLUME - Adjusts the SL-67's overall output level and offers the flexibility to dial up rich, high-gain overdrive at any volume.
SPEAKER OUTPUTS - Two loudspeaker outputs wired in parallel with 3-way impedance selector switch for 4Ω, 8Ω & 16Ω.
SPECIFICATIONS:
Output: 50 Watts RMS
Tubes: 2 x EL34 and 3 x 12AX7
Front Panel: Power Select Switch, Presence, Bass, Middle, Treble, Volume I, Volume II controls and four inputs
Back Panel: Master Volume, 2-Speaker outputs, Impedance selector (4Ω, 8Ω, & 16Ω), HT Fuse, Mains Inlet and Mains Fuse.
Dimensions: 26" (W) x 8.25" (D) x 10.25" (H)
Weight: 42 lbs.
Thanks
VARIAC™* POWER MODE
POWER SELECT SWITCH
SPECIFICATIONS:
Weight: 42 lbs.
