Pete Farrington
Where did you buy that?J taper master volume
Cool, what about taking an origin and doing that?Here's my second go at a hand wired mod, this time with board mounted tube sockets and using the existing standoffs to make install easier. Used a 5H choke on this build. Push pull high gain mode and push pull fat boost for stage 3.
Modified Zero Loss FX Loop
Modified DI
Modified Power Supply for 12VDC circuit, uses a chassis heatsinked voltage regulator instead of voltage dropping resistors that heat up.
Switchable Fixed Depth Circuit for the negative feedback loop to add a bit extra low end fullness when needed.
Post phase inverter J taper master volume.
They don't exist, so I had to custom make it. I took a dual gang 24mm CTS pot, opened it up and since most of their 24mm pots use the same size track boards and wiper system, I just replaced the carbon track boards with matched CTS 250k J tapers as close as I could get to 220k from the bag of 20 that I bought. I settled on some that measured super close to 220k and then I used resistors from the wiper to ground to get them to read 220k when the control is full clockwise.Where did you buy that?
Where from?CTS 250k J tapers as close as I could get to 220k from the bag of 20 that I bought
I get my single gang 250k J taper pots from CE Distribution, which is either Amplified Parts or Antique Electronic Supply on the retail end if you don't have a resale license to sign up with CE. Purchase linkWhere from?
Wait until you play a modded one though. There are tonal possibilities there to unlock. One of the best ones is polyester film and foil capacitors like Sozo mustard caps. Then you can cascade the channels and get some really tasty higher gain overdrive on a switch.I cant imagine doing mods to my SV20H it sounds great as is!![]()
Am I seeing it right that the NFB is on the 4 ohm tap? Compared to the 1959 HW, which has the same NFB resistor value and has it on the 8 ohm tap. Curious. Should make a somewhat big difference, shouldn't it?
If you don’t have any experience in amp modding, you shouldn’t proceed for a number of reasons.Question for you amp modders and builders. I have a stock SV20H, and would like it to be more in the realm of the Master Volume JMP of the mid 70's, how can I achieve this? I believe that I just have to cascade V1A, and V1B, then add MV. If this is correct does anyone have pics of the items that need to be changed on this board. I'm new to modding amps and understanding schematics, so I'm a little unsure how to proceed.
Thank you for your input, although I don't necessarily have experience modding an amp, I'm no stranger to a soldering iron and a PCB. I'm also not afraid of damage to my amp as everything could be fixed with additional work if needed. I'm just not certain how to read the schematic for the 1959, and JCM 800 and translating that to the layout and relate it to what needs to be changed to make one closer to the other. I also am currently running this amp through an Ironman Mini Attenuator, and using a RYRA 808 OD pedal in the front end. I would just like to get more gain from the amp and use the pedal more like a solo boost or something like that. I also was under the impression that the JMP was based off of a 1959 with connected V1A, and V1B together to achieve a higher gain structure as well as a PPIVM, which then was renamed to be a JCM 800.
