Pete Farrington
I’m interested to see them, if you don’t mind looking them out, thanksI wrote them down if you need them.
I’m interested to see them, if you don’t mind looking them out, thanks![]()
I replaced the 4n7 bright cap with a 100pf. Any 100-470pf will work well. Choose for your required brightness, the higher the brighter.. View attachment 95310
Actually the lower value a bright cap, the higher the frequencies it lets go through. As you increase the value of the bright cap, you let progressively more high mids and then mids (for big values like the stock one) go past the potentiometer. Of course, when you start passing high mids, you have more volume, that’s why a lot of people go wrong with saying it’s brighter, but if you normalize volumes, it’s definitely not.
The stock value is so big, the volume pot actually really acts as a bass roll off control more than anything.
Giulio
No, I didn’t. He wrote “the higher [value], the brighter”, instead it’s the lower, the brighter and I explained why.I think you may have misread the post you replied to.
Giulio
I’m sure it’s you, which should read againPerhaps re-read it again
ANY MODS FOR MORE BASS?
Hey guys. I just picked up a new SV20 head. I’m playing it through a 1x12 with an old JBL D120. Amp sounds great, better than I expected. I play it with High Treble volume on 8 to 9. And mixing in Normal volume at around 4 to 5. Convincing plexi tones, I just wish I can get more bottom out of the amp! At the volume I’m playing the bright cap is pretty much already pulled out. My issue is if I try to mix in more of the Normal volume the bottom end gets muddy. I’m guessing due to the small transformers. Same happens if I try to mix in more bass. Overall the amp sounds great but a bit hard and brittle. So I am going to try a set of Mullard XF2s I have on the shelf and some other preamp tubes. I’m sure I can soften it and sweeten it a bit. But I don’t think those things will give me a bigger and tighter bottom end.
Is it possible with the high treble volume on eight the bright Is still somewhat engaged? Should I try snipping it?
I am new to this amp and sorry I have not gone through the couple hundred pages here but wondering if there are any mods I can do to the circuit to fatten that bottom end?! Thanks!
Hi - the method @Franksamps shows in post #44 above is the easiest as the bright cap is on the daughter board and easily accessible. IMO ~470pF is a sweet spot, but experiment with some alligator clips to find what you like.
Also you could increase the V1B coupling cap from .0022uF to .02uF. This would move the amp a little more towards a bass-spec plexi.
Good luck!
Thanks for the reply and sorry to bug ya all on Christmas day!.... so I will experiment with the bright cap for sure, I generally removed them completely from my vintage plexis... also for the most part I always replaced the .0022 with .02 on my vintage plexis as well...
BUT, Im not much of a tech guy and never heard of this amp until a few days ago, not familiar with it... would anyone have a pix of where I can find the V1B coupling cap?
Thanks!
Hi, a bit of a random question from a new member: does anyone know if the power voltage on the SV20s can be converted somewhat easily?
I was hoping it used a multi-tap transformer. Oh well, that’s what step up/down transformers are for.I dont believe so sorry. I think it requires the power transformer to be changed and I dont think Marshall sell replacements.
whats up!Does anyone know where the phase inverter coupling caps are located on the SV20? I think I have an idea, but just want to be sure. Converting it into a mini Superbass.
