JammyDodger
SOLD
I have for sale my Marshall Silver Jubilee Combo. It's in excellent condition. Hand made in the England. This is the amp made famous by John Bonamassa, Slash and John Frusciante.
Price is $1500.00 shipped in the CONUS
From the Marshall Web Site......
The Studio Jubilee delivers everything from sparkling cleans to gritty distortion. With clean, lead and rhythm sounds to choose from, this classic amp is adept at providing a range of styles. In addition to the 3-way EQ and Presence control, there’s the option to engage the pull rhythm clip function for extra crunch.
The 2525C’s all-valve sound is driven by two ECC83s in the preamp along with an ECC83 phase splitter and two EL34s in the power amp. You can also add in extra grit by engaging the pull rhythm clip.
Marshall 20-watt 2525C Mini Silver Jubilee Amplifier Combo at a Glance:
* Classic lineage
* Perfect power
* Straightforward design
Classic lineage
The original Marshall Silver Jubilee is one of the most sought-after tube amplifiers in all of rock history. Their aggressive sound was widely used in the '80s and early '90s by hard rock players of all types. Marshall's reissue started with that iconic design and upgraded it. And the 2525C Mini Silver Jubilee takes that one step further by putting all of that sound into a more compact combo amp with a usable 20 watts of tube power.
Perfect power
If you're a gigging guitarist, you know that keeping the stage volume down is becoming an absolute necessity. While older 100-watt amps sound amazing, they often require a lot of stage real estate and sound their best when you're pushing the volume. The Marshall 2525C solves this problem by putting the Silver Jubilee sound into a 1 x 12" combo that pushes 20 watts of all-tube power, the perfect amount of power for headroom and grind on modern stages. And if you need even quieter performance, you can switch the amp to 5-watt mode.
Marshall amplifiers are historically known for their ease of getting a great tone. Though Marshall has some powerful designs with a lot of tonal options, amp designs like the original Plexi, the JCM 800s, and the Silver Jubilees have straightforward panels that let you turn on, turn up, and play. You still get a great effects loop and the low-power switch. But the panel is easy to navigate, and it will get your tone dialed in quick and easy.
Marshall 20-watt 2525C Mini Silver Jubilee Amplifier Combo Features:
* 1 x 12" combo version of Marshall's popular Silver Jubilee amp heads
* Same tone as the iconic '87 Jubilees
* 20 watts is great for performance volumes, 5 Watts for the home studio
* Switch to 5 watts for rehearsals and recording
* 1 x 12" Celestion G12M Greenback speaker
* DI output
* Effects loop
* Classic lineage
* Perfect power
Classic lineage
Perfect power
* DI output
* Effects loop
