colchar
This thread is amazing. Even for someone like me who is functionally illiterate when it comes to electronics, it is amazing to read through all of this and to see the collaborative efforts and the community spirit (becoming much more rare these days!).
I am going to have a chat with someone here about one of these units, but wanted to ask a couple of quick questions here before speaking to him in person (it will help make me sound less of an idiot and he won't have to give me the 'For Dummies' explanations if I can tell him exactly what I want).
I only play at home, and never record so I only need an attenuator with no other functionality.
1) Is it possible to get a unit that works with more than one impedance? I am currently using a Hughes & Kettner 2x12 with V30s, which is a 16ohm cab. But I might want another cab at some point so was wondering if I could have that factored into a build now, or if it would necessitate another attenuator later?
2) I am currently using an Orange AD30 (I also have one vintage and one modern Traynor combos) and am very happy with the amp. It has master volumes, but I want to be able to push the power tubes to open the amp up. I cannot ever see myself diming the thing, it would likely only be played at 50%-75% of its volume. But I will be buying another head at some point so wanted to factor that into the attenuator build. I am currently thinking of grabbing an SC20 or SV20, but am open to other Marshall heads - if a 50 watt JMP, Vintage Modern, or JCM800 was to come along I'd snap them up. Then again, with a good attenuator maybe a Class 5 would be enough since I'd be able to turn it up nice and loud while controlling it with the attenuator.
But basically what I want to ask here is whether a 50 watt version of the attenuator will be enough for the amps I have mentioned? Even if I pick up one of the Marshall 50 watters mentioned above I cannot see myself diming it, and would only play it at 50%-75% of its volume.
3) Since I know bugger all about electronics, is there anything else I should be thinking about or is everything pretty much covered?
Thanks in advance.
Thanks in advance.
