@Gene Ballzz ,
Thanks for taking a look! You’re right that the wire termination and soldering is rough. It was my first soldering since the pandemic. I should have practiced a bit to knock off the rust before jumping into a real project, but my impatience won out. The Bassbreaker I have is the 15W head, purchased, I believe, in 2017 or 2018. (Tried to link, but I don't have the 5 required posts to do so. It's model #2263000000 on the Fender website.) I’ve attached some photos of the attenuation box without the tape, special focus on the input jack. Thank you again for any time you can/do spend on this.
Thank you, @JohnH ! I ran the tests, and I’m getting measurements that differ significantly from the expected results. Both tests come back at 6.5/6.6 Ohms.
Out of curiosity, I also re-ran the pre-startup resistance test and discovered some interesting things. My measurements no longer come in at the 6.9-8.8 range I had before my initial startup. Instead, I’m getting 6.4/6.5 on all switch combinations that have stage 4 disengaged and 8.2/8.3 on all combinations that have stage 4 engaged. Stage 4 is the switch on the left-hand side in the photos. I'm not sure if any of this is related to my problem. It just seemed odd that the readings were no longer showing a minimum of 6.9 as when I originally tested and that the stage 4 switch is the only one that impacts the measurements. I used the same speaker and speaker cable for all of tests (when applicable).
I plan to reexamine the connections very closely when I can to see if a connection failed. Clearly something is wrong with the reactive stage, but it's not immediately apparent to me what is happening. I’ll be thankful if you can make sense of these measurements.
Photos without tape:
