Barnsley Boy
Nice one @JohnH .
Under criteria 1: 4 ohm speaker load with the added front end, at max attenuation 18 ohm, with -7db attenuation 12 ohm
Under criterial 2: I've got 17.7 ohms at max attenuation, and 15.5 ohms at -7db
Not sure why the first set of readings is so high, but the 2nd set seem to be close enough. I'm gonna connect it all up and give it a gentle test run. Just need to make sure I flick the the right switches (best case scenario I get some beautiful power tube based overdrive, worst case it's good bye Putin!)
