I used mine for 5 years or something, when i installed it it didnt really do much difference compared to the originals in my Aria Les Paul. So i let it stay installed. Now I switched back, and Im trying to find out what year it´s from, it cant be from the early 70´s cuz it is a 4 conductor, but i can´t find out what year that was released, the original was 3 conductor and the name was "Dimarzio Super Distorsion, the Dual Sound®" I measured almost half the resistance compared to what´s in the spec´s at dimarzio.com, has it maybe changed over the years and a brand new today is hotter ??? It was a bit to hot, could do with less. ....mine is excactly 8 Ohm, and 13.68 Ohm is the Dimarzio specs
And when I snooped around some more I found out about the standard and F-spaced size. And in the PDF on that there is pictures from straight above the pickup, and next to that there are two pictures looking from the side, and one of them looks like mine, the twelve screws goes straight through and out the bottom and it has the same thickness as the picture, .573 inches .... the ones without screws straight trough are .631 .... So i have a standad spaced I know that much at least.
was there ever a super distorsion for use in the neck position or what? I could see why it´s half the output in that case, but i cant find any info. But hey it worked great in the bridge position.
those two pics with two different looking pickups from the side is on both the f-spaced and standard sheet.
Hope I dont sound to confusing....
I want to know what it is i have =)
