Mitchey_Ritchey
- Joined
- Jan 24, 2022
- Messages
- 5
- Reaction score
- 1
Hello, maybe you can help me, as I am not a specialist but just a pure "user"
When I play the amp and boost my solos with the "Boosta Grande BG-20" clean boost pedal
(up to +20dB of transparent clean boost), the volume only increases minimally!
No matter which channel I use on the amp and how high I set the booster.
I don't use an FX loop but connect the guitar to the booster and then to the amp.
I also use various other amps in this way (VOX AC30C2X, Ibanez TSA15H, Laney IRT120H Ironheart)
and I don't have this problem at all - only with the JVM205H!?!?
The amp has just been completely checked and fitted with new tubes.
Apart from that, the amp runs and sounds sensationally good!
Do you have any idea what the problem could be? Thank you
