Maggot Brain
You need volume!
The biggest draw back (for some) of the Origin20 is it doesn't come alive until you start pushing the volume. It's designed to kind of mimic the old NMV Marshalls and it's 'Gain' control is fairly non functional until the power section starts breaking up, that's when you can tailor the amount or gain/thickness with the 'Gain' control but kinda figure your ACTUAL gain control is the Volume and more volume will bring the the amp alive.
In situations like this I'll use a drive pedal to substitute for the lack of volume and drive from the power amp etc. A reverb in the loop will also help it sound bigger and more "alive" at low volume.
I think getting a decent drive pedal (I use a Digitech Bad Monkey, TS9 or a Lovepedal JTM and they all worked great with the Origin20c). Once you get that figured out you'll be able to dial in the rest.
You may want to consider actually looking into a DSL if you are going to play at lower volumes more often. The Origin20 is a cool little Marshall but kinda fails at low volume stuff imo.
As others said, attenuator would help too.
Good luck.
Good luck.
