ELS
- Joined
- Feb 7, 2021
- Messages
- 602
- Reaction score
- 460
Modified and original.
Was the amp engineer at fender drunk when he designed the original circuit? You can easily delete 4 resistors, 1 capacitor
and 1 triode stage (so no need for that dreaded "only one triode used" socket in these amps). (1 less tube)
Also this would increase gain, you wouldn't need the 2nd stage in the tremolo channel. the way 2 tubes are connected it's a mixer, and has a bit higher gain than using resistors.
And there's like no need for the cathode follower for the tremolo oscillator, I think when the engineer started making the design, it wouldn't oscillate with the .1 caps to ground, so he added the CF, but after reducing the intensity with the 4.7Meg he didn't realize that the CF wasn't needed.
So here's a simpler circuit only needing 2 tubes and does the same thing.
There's more ways to delete parts here but at that point the circuit starts being different, consequently a different sound.
