Garth Rocket
I will be taking these to Robert Dixon in Burbank, CA to get dialed in. I got a great deal, so spending money on a great tech works.Great score. Take good care of it
Do you want the lowdown on them first?
I want the lowdown as well !Even if he doesn't - I do!
That would be amazing.Do you want the lowdown on them first?
Yes, I always like your comments!Do you want the lowdown on them first?
I’m not familiar with Skip. I’m guessing he is in Nor Cal? I’ll look him up. ThanksIf I was in California I'd take them to Skip Simmons.
Interesting….I’ve only had experience with a few techs and so far, my gear has works best after Dixon has worked on it. I’m know there’s other great techs around. So Cal has pretty good resources"The lowdown" makes it sound like you're going to reveal one of them started life as a Peavey or something
Great! Just be sure to ask him to be "conservative" with the original parts. I have a friend who took a similar era Marshall to him recently and he replaced a mustard cap. I'm sure there was a reason, but those caps are notorious for not leaking DC after all these years, so I do wonder how necessary it really was.
Absolutely!Do you want the lowdown on them first?
Check the gut shots!Perhaps gut shots before you take them for servicing would be a better idea, there are tech's out there who know they're stuff, but the best knowledge is right here.......
Considering it's 51 y.o. that's not too bad, right?The lead has replaced OT and plate resistors and B+ droppers, couple of replaced Octals. Both have replaced switches and lamps.
The lead has the v1 cathode mustard replaced and v1a has lost its 0.0022uF coupler
The trem is otherwise very original
Yep the tone shaping caps and pots I noticed too but kept it light 😉A few addition things I noticed on the Lead amp are:
Replaced Ohms selector switch.
Replaced Treble pot & the Normal channel Volume pot.
Replaced 0.005uF ceramic disk bypass cap on the Bright channel Volume pot.
Missing the 500pF bypass cap for the Bright channel's 470K mixing resistor.
I was thinking the Super Trem looked very clean! Which seems to be extra rare with those...
That’s what I’m thinking, but others may know better!Considering it's 51 y.o. that's not too bad, right?
