Hey all, I apologize for yet another troubleshooting thread, but I honestly wasn't finding the information I was looking for.
Basically, I just got a JCM 2000 DSL100 (1999 build), blew an output tube (tube 2 when looking from the left) and ordered a new set to replace it.
- I started by making sure the speaker was still plugged in, no input is plugged in, and pulled all the output tubes.
- I verified pin 5 was stable (grounded to chassis, positive probe in pin 5) and saw steady numbers in each tube's pin 5 on standby (.28-.030) and steady voltages when warmed up (on for about an hour) both on standby and off standby (.016-.017).
- I put the new tubes in and tried reading the bias pins and the left side is sitting at .9mv and the right side is sitting at .6mv.
- When adjusting the bias screws nothing changes no matter how far i turn them
- I tried this with standby on and standby off, with standby off (amp live) and I heard a LOT of noise through the speaker with no input (volume at .5/10)
What am I doing wrong here, or is the amp hosed?
Edit: I tested pin 5 wrong and used VAC not VDC, I updated the results in a later post but will put them here as well.
Voltage DC - Output tubes from left to right (when viewing the back of the amp)
1 2 3 4
-41.79 -40.70 -43.93 -44.55 Cold, Standby Off
-42.72 -42.73 -46.14 -46.13 Warm, Standby Off
-42.38 -42.39 -45.78 -45.77 Warm, Standby On
1 2 3 4
