New Old Amp Day: My Jtm60 3x10 Also Known As Jtm 610
Igor_torcamaniac
Munich
My FX loop worked OK, until I put a cable in it. It started crackling from that moment. When I opened the amp, I cleaned the FX connectors with contact cleaner and that fixed it.
I always have a patch cable at hand, just in case...
Indeed the boost channel is somewhat usable when you keep the gain low.
I changed all 4 jacks in FX Loop with Neutrik.
Anyway, I use some pedals in Serial Loop and Parallel is always patched, because I like the sound of the amp with Parallel Mix pot to max better.
EvoRider
Hate to drag up a old post but was wandering how it has worked out...
I recently ordered a jtm 60 1x12 and am waiting for it to be delivered.. I haven’t had a Marshall in years...
IOSEPHVS
Ohio
Nice find. I am looking for a JTM60 or JCM600 head. The heat problems on some of the JTM60 series amps might be related to not all of them being vented out the top of the cabinet. I have seen some with top vents, and some without. I have a JCM602 which is vented. The JTM60 and the JCM600 series are only cosmetically different, and all of the PCBs in my 602 are labeled JTM60. I am surprised that yours is running 6L6s. Mine has not been modified, and I have never had a problem with it. They are loaded with features, and I have found that mine sounds best with minimal preamp settings, and the power section cranked at about 7.5/10.
Dawgfanjeff
I am an original owner of my JTM 60. I put it aside for a few years after some reliability issues (fuse replacements) but am looking to resurrect it again and get it running. I was always concerned about that heat issue, and can't say that my issues with it are heat related, but just in case, I fashioned a shield from an old thin license plate and covered it with adhesive flexible heat shielding tape. The whole arrangement shares screws with the cage to mount it. I think I'll shield the transformer adjacent to the tubes, too.
stephen santamaria
Last May during one of Melbourne's many lock downs, I bought a JTM60 3x10 from a friend who owns a music shop. Never tried it but did it to help his store out. I replaced the Svetlana EL34s and had it biased. The tech says it has to be biased hot to get the best tones out of it. I currently play my Wolfgang Special HT thru the OD channel and have the following settings: gain 7-8 (10 o'clock) ; vol 10; bass 0; mid and treble 10; reverb 0; presence on full; mv at 4, or if no one's home, 6. To my ears, it has a live Angus Rock or Bust kinda vibe. For some strange reason, sometimes i have to run it bass 1, mid 3.5, treble on 8.5 and presence between 4 and max to sound similar. Don't know if its the amp or the Wolfgang pickups or the fact that I have slight ringing in my ears. It never sounds the same 2 days in a row unlike my fav setup, Tech 21 Plexi fly rig, which nails it every time.
would appreciate some thoughts....
Igor_torcamaniac
Munich
Can you test this again with both FX loops in the back always jumpered?
