Matthews Guitars
- Joined
- Aug 17, 2019
- Messages
- 6,389
- Reaction score
- 10,321
I think you need to gain a better understanding of resistors in circuits.
The voltage drop across the resistor is very important. It tells you what's going on.
If it's grounded on one end, then it will read supply voltage on the supply side and zero volts on the grounded end.
It should not read zero volts on that end if it's not supposed to be at a ground point. If it is, what follows it is a hard short to ground.
You've got a 4.7K resistor that baked due to a shorted tube and it was telling you, very clearly, "The circuit is drawing too much current through me!" It's basically pointing right at the problem. It'll almost always be the device being fed by that resistor, which can draw current.
You need to know how to calculate whether or not a resistor is big enough to handle the current it's going to experience in circuit.
elecurls.tripod.com
Learning electronics makes troubleshooting infinitely easier when you have a problem with your build.
Dropping Resistor, Explained
