paul-e-mann
- Joined
- Dec 7, 2009
- Messages
- 19,229
- Reaction score
- 20,748
The bulb doesnt light with the power tubes out. The bulb lights with either of the power tubes in and in either socket. I had a speaker connected to the amp during this test.So...when you pulled the power tubes and tried one at a time, did you actually try the scenario of just leaving both power tubes out? That's a fast test that would've told you if at least one power tube is bad if the limiter bulb was now softly glowing. ? I've forgotten what I've read, but you've verified your speaker and connections since you need one connected with all tubes in, right? Also, a Fender usually has you wire the output jack so it shorts should the speaker cable be jerked out. Kind of a failsafe for the output transformer vs. the open circuit which you really never want at the speaker jack. Check everything,...measure it.
Also, I can't get a good visual on the rectifier socket with the stray wiring. Can you post a photo of that? Specifically peek and verify what transformer wire colors are on pin 2 & 8...should be black and white going direct from the transformer for the 5vac according to the transformer wiring chart on the transformer.
The output wires of the OT (green 8 ohms, yellow 0) yellow wire connected to the speaker jack sleeve and switch terminal, green wire connected to the tip terminal, then green jumper from tip terminal to the extension speaker jack tip terminal.
The rectifier socket, from the PT 5V black wire on pin 8 and white wire on pin 2, also on pin 8 is a red wire to the standby switch, pin 4 and 6 have the green 340V wires.
