hi13ts1
- Joined
- Apr 21, 2018
- Messages
- 14
- Reaction score
- 52
Hello all. I've been searching for a 2266C for a bit of time now as I was needing to maximize portability and volume control after playing my 2266 head and 2x12 cab for several years.
I have a 2266 head I paired with the 2x12 Egnater Tweaker cab that I put a V30 in for one of the speakers. It was an excellent sounding rig and my main one for years, but it got to a point where my gigs became numerous and the venues/sound guys were less consistent, so for convenience and tame-ability, I switched to a Fractal unit. It was incredibly impressive, but with all that it could do, there was something missing. As close as it got the feel of a real tube amp, it's still not 100% there. Also, an FRFR cabinet on stage does not feel and sound the same as Celestions roaring behind you. So I thought the best compromise would be to get the combo version of my 2266 and mod it to the point where it met my criteria for portability and volume control.
I was able to find one from N Stuff music in PA after a few months of searching. It sounded great right out of the box and I was thoroughly impressed with the G12C speakers loaded in it. Incredible tone. So after the obligatory retubing and biasing, in order to meet the portability function, I installed casters and begrudgingly took out the two G12 and replaced it with one Neo Creamback. This made the amp go from almost 70 lbs to a little under 60. I can one-arm it if absolutely necessary, however, with the casters, I've found that to be a rare event. I mounted a piece of plywood over the empty speaker hole as I liked the semi-closed back tone it had as opposed to a ported cab. For volume, I mounted a Torpedo Captor inside the cabinet and cut a rectangle out of the back panel to mount a Rockboard pass-thru XLR/Power port. This allows me to centralize the AC input as well as the output for the DI on the Torpedo. The DI is based off a 4x12 with V30s mic'd with an SM57. The emulated out actually sounds pretty good and has been my go-to method for all of my gigs so far. The most important part of it is the fact that I'm able to either attenuate the volume 20db or cut the speaker entirely and go direct if the venue and/or soundguy is really unforgiving.
I'll try to get some in-depth pictures taken, or better yet, a video made to share all of this. I'm happy to say that it's working exactly the way I want it to and is giving me back the tones I've been missing since switching to digital. The Fractal is still being used, but now as a multi-effects unit and/or amp backup. God bless Steve Dawson for designing such a wonderful amp. It nails the early-mid 60s Plexi tone that we all associate with Marshall, but it's given much more gain on tap and tame-ability volume-wise. In the meantime, I've recorded a Gary Moore song with the amp and my 2019 Gibson R0. I think it's very close to his live tone in the few years before his passing. I know he was using a 1959 SLP HW, so not quite the same amp, but the same vibe. I recorded the emulated out on the Torpedo as well as mic'd the Neo Creamback with a Sennheiser e906 and blended the two. Sort of a fitting tribute to Jim Marshall as well, given yesterday was the 10th anniversary of his passing. Thanks for reading through my post!
