Hi guys! Been lurking here for a while, but finally took the plunge the other day and brought home a 1969 JMP 50. Sounds amazing, but needs some cosmetic TLC
Firstly, the previous owner had the front tolex and head cabinet partially painted in gold (!). It actually looks kinda cool, but I would like to have it restored to former glory if possible. I do prefer the old beat-up look so not wanting to get it "as new", and as such re-covering it is not an option for me. As far as I can tell (and according to the guy I bought it from) the tolex is original. For the faint hearted, please avert your eyes
I was wondering if you guys could help me with the following;
What is the best way to remove old paint (from the early 80ies)? I've read about duct tape, paint remover, naphtha, etc. I tried with a soft toothbrush and some mildly soapy water but that did not work.
What are the correct dimensions for the piping labeled1, 2 & 3 in the following picture (not my amp in the picture) and where can I find decent repros? Also, I have been told (as mentioned) that the tolex is original but shouldn't there be visible grooves where the horisontal piping (#3) and top piping (#1) are?
I've tried finding a decent "step by step" guide to replacing piping but can't find it. It seems fairly straightforward but all tips are welcome
I also need a couple of new knobs, any links to decent sources (or where I could find some originals) is much appreciated.
Otherwise the amp seems to work well. AFAIK one cap has been changed, and at some point an effects loop was added (!) but has since been completely removed. I am completely ignorant to the workings of amps, but thankfully there are a few knowledgeable amp doctors here in Norway that can assist when/if something goes haywire. A couple of images from the innards are following.
I have found an all original 69' cab locally that hopefully will be joining the top shortly, will keep you posted. In the meantime, thanks in advance for all tips and thanks for a great forum!
