Noob question but I will try and explaing. Got a Mini Jubilee with 2x12 cab 2 months ago... Honestly love it...
It does great cleans even in a band context really cuts trough the mix and ofc some amp overdrive alone or boosted with TS, Klon style, boosts like FFX it does it all really well.
But started thinking about tubes so my next questions are:
I know that the Mini Jub doesn't need biasing because it is cathode bias (in my case that is amazing because hard to find a tech nearby and a good one at that).
Also I know that it uses 2 EL34 tubes in the power amp and 3 ECC83 or 12AX7 in the preamp.
I am based in Europe and as far as I noticed my best bet is to buy from JJ tubes directly becuase most shops that sell tubes charge a lot extra.
But if you have anything else to recommend feel free to do so, my tubes right now are JJ's that came with the amp and with nothing to compare them I love the sound.
Also at least talking for JJ i see that they sell different types of EL34's for example and now my MAIN QUESTION is if you could educate me because the tubes that are right
now in the amp seem to be an alright balance between getting saturated gain tones and nice cleans (looking for versatility).
So if there is a thing in tubes like for example "with xyz tubes you can get a hair more headroom or more saturation" could anyone inform me on that please?
(not really looking for more saturation because max I would play something to like hard rock territory and there is more then enough gain on tap in the amp on its own
so I guess that I would look for tubes that are similar to the stock ones or with a hair more headroom).
And how often do you need to change power amp and preamp tubes? Based on that I will probably buy a pair or two in the following months.
I play the amp maybe 5-8 hours in a whole week (depends maybe less maybe more if there is a gig) so lets say 2 times per week band practice but for general use
I play a small solid state practice amp and my main amp the Jubilee is for band practice and gigging.
Hope I can get some help on here, thanks in advance.
