F86
- Joined
- Oct 18, 2020
- Messages
- 15
- Reaction score
- 40
Question about the Mini Jubilee, which I haven't been able to answer reading articles and reviews. After lot's of trial and error, I finally have a setup that allows me to have exactly the right volume boost for leads in my current band. Loud original rock with two guitars (humbuckers or P90s in both), both through Marshalls. I was never able to get quite what I wanted (boost-wise) with my 2204, but have it completely solved with my 2210. I keep one of several rangemaster-style drives through the front, and have the unboosted channel sounding great. The boost channel has the volume and treble cranked a little higher, but gain fairly low (boost pedal stays on all the time). The result is very similar tone on each channel, but a noticeable volume/treble boost for lead. I'm very happy with this setup, and can easily dial in the amount of volume boost I need (which stays pretty consistent with Master Volume adjustments). Now I'm wondering whether I can replicate this concept with a Mini Jubilee and a 2x12. With careful dialing in (both on the amp and pedal), will the 2525H allow for a hot, driven tone in the same ballpark on each channel, but with more volume on the "boost" channel? I realize it doesn't work the same as my 2210 (which obviously has completely separate controls for each channel with a common master), but I haven't found one locally to demo and I'm really curious.
Thanks for any enlightenment!
