I wonder if the "one wire" mod (bypassing L2 and C1 in the schematic) really improves the tone.
I've done the one-wire mod on both of my PB-100's, and all technical reasoning aside, I like the results. I was originally going to make it switchable, but after trying it, didn't see a need.I wonder if the "one wire" mod (bypassing L2 and C1 in the schematic) really improves the tone.
I'm not seeing that the tone needs improving, sounds fine as is.I wonder if the "one wire" mod (bypassing L2 and C1 in the schematic) really improves the tone.
Hi @playloud Some subtle interactions going on with the transformer the load and the speaker! The dB differences noted at very high frequency are probably based on signals that in that range, are at very low volume, since guitar speakers don't have much to say up there. When I do such tests, I mic a cab, but I see that yours were using a TAE after the output? I wonder how accurate the TAE is up at those frequencies?
I tried that mod and made my sound not too good. Sounded way better with that cap.Yes, I have a couple of them, and they both always stay fairly cool, barely warm when cranking a 100w amp. They use a unique design, where the cooling fan is powered by the signal flowing through the unit (fan spins as you play). There's also a one-wire mod that makes the unit sound even better (IMO), It basically shunts the electrolytic cap.
Like I always say, whatever works.I tried that mod and made my sound not too good. Sounded way better with that cap.
