Hi all,
A friend asked me to take a look at his Marshall IBS 3505 30W Micro Bass amp. Schematic is attached. He had got a nasty shock while connecting a pedal to it (Fender Metal pedal). Apparently he was holding up the pedal in both hands and turned it on and immediately jerked bolt upright and couldn't let go of the pedal. Lasted for a few seconds and then luckily an RCCB or MCB tripped and he was saved.
I've had a brief look at the amp. There was a transistor whose leads hadn't been trimmed properly but I don't think they were making contact with the chassis (i've clipped them now). But the mains lead was very loose in the back of the amp so it is possible that the Earth connection was intermittent. The earth wire connecting the mains socket to the chassis was sound. And I'm giving him a new mains lead that fits snug in the socket.
There was no voltage between the tip and sleeve on the input to the amp - and I tested this a number of times and after leaving the amp on for about 30 mins.
Though it seems safe, I am a bit worried about giving it back to him without knowing exactly why he got this serious shock and without being able to reproduce the problem.
Any ideas as to a possible cause?
Could it be the AC/DC 9V adapter that he was using for the pedal? He said it was a cheap one that he had found somewhere in the house. Is it possible for it to fail so that 240v is going through the chassis of the pedal and hence the shielding on the guitar lead plus the chassis of the amp. If the mains lead on the amp was not grounding the chassis then it doesn't trip when it should and he ends up completlng the circuit??? DOes that make sense?
Unfortunately he had thrown away the adapter before bringing me the amp so I can't test it.
Any thoughts gratefully received,
Tom
Tom
