Marshall JCM800 2205 help needed
gibson17
Hello all,
My friend brought me a JCM800 2205 that was having issues producing any sound. I took the amp in and disassembled it. There was a bunch of cold solder joints on the board that I reflowed. The resistor on R59 was burned and failed open. I replaced that with a new resistor and also replaced R58 since it was the same resistor with the same value while I was there. The R58 resistor was still in operable condition. All the tubes are fairly new and test well on my TV7. The power tubes are within 1 GM of each other.
I am now able to get volume and sound from the amp but I am having a few issues.
1) Even though the tubes are closely matched to each other the tubes are more than 10mA apart. One side at 44mA and the other at 32mA. The bias pot is turned all the way down and that's as low as it will go. I'm getting a fair amount of noise which I am assuming is from the power stages being that far apart. Shouldn't the tubes be somewhere around the same current, especially of they're closely matched? What should I check?
2) I know I need to change the resistor that feeds the bias pot so I can gain better adjustment. I've had to do this on other amps... Which resistor should I be targeting? I do have a decade resistor that I can put in place to find an appropriate value.
Thank you in advance for your time and knowledge.
gibson17
Hello Pete,
The tubes were bought as a matched set. I measured the tubes on a calibrated Hickok TV-7 D/U. The GM was one digit apart at 46/47.
I measured the currents with a dual bias probes from SRS into a Fluke 115.
My plate voltage is 464, so I'm aiming for 37mA but the pot is bottomed out at 44mA.
RadioAD5GB
No man. A class AB1 circuit really isn't that complicated. Don't over-think things. First of all, what's with the huge disparity in OT current? Got a 'scope? Signal generator? All the junk you need to safely probe around in a live tube circuit? ( these things CAN KILL YOU ) If so, OHM's law - and associated math, will be your friend! E = I*R and all of its permutations. Seems to me you're already on the path to success. Don't discount however,, the odd and - off - chance of RF parasitic oscillation. I myself, have never seen it in Marshalls, or decently wired clones, but it's been known to happen. Current sucking tube like you described , with no other reason...... that's when I jump into A/C diags and don't forget the possibility of RF parasitics........
Have Fun!
danfrank
Hello Pete,
Hi,
You said "bought as a matched set". Where did you buy? The reason I ask is because some places sell "matched sets" that aren't matched... Like Tube Depot, their matching sux! Lol! CE/Antique Electronic Supply does well at matching and it is worth it to pay the extra few $$ for "burned in and matched" sets... This weeds out most failures before you buy the tubes.
Also, matched by Gm is only half the equation... Tubes need to be matched by Gm AND current, these are two different tube parameters... The original Groove Tubes used to do it this way. Think of it this way: You can consider Gm matching as "dynamic matching" and matching for current as "static matching". Both need to be done for a truely matched set of tubes.
Hope this helps
gibson17
No man. A class AB1 circuit really isn't that complicated. Don't over-think things. First of all, what's with the huge disparity in OT current? Got a 'scope? Signal generator? All the junk you need to safely probe around in a live tube circuit? ( these things CAN KILL YOU ) If so, OHM's law - and associated math, will be your friend! E = I/R and all of its permutations. Seems to me you're already on the path to success. Don't discount however,, the odd and - off - chance of RF parasitic oscillation. I myself, have never seen it in Marshalls, or decently wired clones, but it's been known to happen. Current sucking tube like you described , with no other reason...... that's when I jump into A/C diags and don't forget the possibility of RF parasitics........
Have Fun!
Hello Radio,
I do have a scope. I have no operable signal generator, the one I have is broken. I do have all the junk I need to safely work inside an amp. I do understand that the voltages are lethal. I have decent mechanical ability but very limited electronics theory. Thank you for the vote of confidence. I'll keep on driving towards my goal, hopefully with some guidance and maybe I'll learn something along the way. What do you mean by huge disparity with OT current? Are you referring to the imbalanced mA per tube?
gibson17
Hi,
Hope this helps
Hello DanFrank,
The tubes were bought from Viva tubes as matched and burned. Perhaps I've fallen victim to poor matching? I realize that the measurement of GM is really theory only. My understanding is that tubes are in inexact science and that the only real measurement was the theoretical GM measurement of transconductance. Thank you for the information and detailed explanation of what tube matching really is. I do have a TV-2 tester that puts the tube into real voltage conditions but it is not calibrated. Is there a way for me to voltage test the tubes so I can have the complete equation of tube matching with both dynamic and static matching?
Pete Farrington
Staffordshire UK
What sort of noise?
I run valves at a greater disparity in idle currents that that, with absolutely no issues.
JCM800 2205 … R59 … R58
Schematic link? It’s just I recall there being 2 very different versions of the 2205. Without that, there doesn’t much point referring to R58 etc, better to explain its function in the circuit, or what it connects to.
myersbw
SW Ohio
Here's a very simple A/B comparison to do regarding the mismatch. Swap the tubes regarding their current sockets. Does the "mismatch" follow the tube or stay with the socket? If the former...you have a tube mismatch. If the latter, start measuring components surrounding the tube sockets to see if values have extremely drifted, etc. From personal experience, I've seen new tubes "matched" that are that far off (sadly enough). Won't hurt to verify that bias circuit and give us the measured bias voltages, too. All the best!
Gblev
Tampa, FL
Gm matching doesn't really matter with tubes. It might make you feel better about the possible longevity of them when purchasing some tubes if the Seller list it, but it's not going to help your amp run more balanced. I laugh every time I see someone selling power tubes as being "Matched" on eBay, and they are basing that off of their tube tester's Gm reading, or Emissions reading for the pair, or quad, they are selling.
As far as having mismatched tubes go, you will hear circuit hum if your tubes are severely mismatched, but this doesn't come through the speakers. There's a lot of players out there that like the sound of mismatched tubes, as they will have an increase in the 2nd order harmonics (overtones) of the sound. If you play loud enough you won't hear the hum. The downside of having mismatched tubes is that means some tubes are working harder than others, and will possibly have a shorter life. As such, you don't want your tubes to be mismatched by too much or it might cost you more money.
I'm pretty sure not too many people worried about mismatched tubes back when they could just go to the corner hardware store, or local Radio Shack, and grab a new tube when one blew. You went there, got what you needed, went home, swapped it in, and was done with it. If it hummed really loud when idling, you thought you got a bad one, so you'd take it back and swapped it for another one. Rinse and repeat until satisfied. If it sounded good, then it was good!
mickeydg5
The middle east of the united states of America
@gibson17
46 and 47 are close. Mutual conductance does matter and power tubes are best when matched to a certain degree. This provides maximum output power aiding in cleaner more balanced output from the push-pull arrangement and does cut idle hum noise.
Why don't you start with providing DC and AC voltages at the power socket lugs?
This is provided you are experienced and comfortable with fooling around in an open chassis which has high voltages.
No one starts with the basics. :noplease:
Also, did you clean all power tube socket prongs and the power tube pins with a good electronics contact cleaner/lubricator?
Pete Farrington
Staffordshire UK
That seems to contradict itself?
I suppose the transformers might generate an audible hum if one valve was conducting really heavily. But then it would almost certainly cause some hum output to the speakers.
Spooky88
Have Fun!
Seems you stated Ohm’s law incorrectly. E = I*R. You’re welcome.
Pete Farrington
Staffordshire UK
This may be useful :)
Gblev
Tampa, FL
Circuit hum, or I'm not sure what you call it? You can hear it from the back of the amp at the tubes. In my experience, it doesn't come through the speakers. This happens when I have tubes severely mismatched, like when I buy a new tube to try and it doesn't matchup to well with the ones already in there.
Pete Farrington
Staffordshire UK
And yes, power tubes on each side of the push-pull with 27% difference are going to put him in the output. The hum usually starts at 10% and get worse as the divide widens.
How strange, that’s not my experience at all :shrug:
I’m not sure it’s feasible to attempt to quantify these things though, eg >x% discrepancy will cause hum, as I think it will be application and scenario specific, lots of variables are in play.
mickeydg5
I set up a bias balance trimmer and tested a few sets and from what I remember is that some started humming at about 10% unbalance difference while others could go higher like 17%+ but none of the sets I tested reached the old adage of its ok at 25%+.
I am not saying it will be the same for every amplifier or every set of tubes but I noted it and keep it in mind.
I have also read the same explained by others in their tech and amp repair books so I have no reason to doubt my findings since I was kind of proving theirs to myself. (I am not giving references; the information can be found in many places and it is constantly stated to use matched power tubes.)
No one has to if they would rather not.
Still I want maximum power so I stick to matched power tube sets.
Franko
Hello all,
One guy told you to switch the power tubes around and see if the same measurements follow the tubes., Do it, and obviously, if the measurements follow get another matched set. As I was taught, you match tubes according to their plate current. I am a straight shooter who gets to the point.
