PowerTube44
- Joined
- Jun 23, 2014
- Messages
- 1,508
- Reaction score
- 3,427
Ever since I got the JCM 2000 DSL 100 a few months ago, I've been running it across a Marshall 1960A (G12-T75's) and a Carvin 4x12 with Carvin speakers. A couple of months ago, I realized that the Carvin wasn't giving me any sound one day, and I found that the secondary speaker jack on the amp was loose from a cold solder joint. I re-soldered it and all was well.
Until today. The same thing started happening, and I could wiggle the speaker cable at the jack and it would come back to life. So I decided to re-solder it again. Nope. Two of the pins were actually broken off. I ordered a new jack that should be in next week.
But in the meantime, running just the Marshall cab in the 16-ohm jack, I made a discovery: it actually sounds noticeably BETTER with just the Marshall cab. Color me surprised. I would have never thought that. So I won't be running the Carvin cab anymore, and I also have no use for the X100B head, since the cleans on the Marshall are just as nice. What sucks is that the market is way down on the Carvin X100B right now, and the cabs are probably even worse. So I'll probably just keep it.
Sadly, I've now discovered that the 16-ohm input on the JCM is also cold-soldered, apparently. The sound will go dead until I wiggle the cable at the jack. I'm glad I ordered two jacks. Are cold-soldered speaker out jacks a known thing on the JCM 2000? Or am I just "lucky?" I'm also wondering if this might be the reason why this one was traded in to Guitar Center, because someone thought the amp was cutting out.
