PowerTube44
- Joined
- Jun 23, 2014
- Messages
- 1,166
- Reaction score
- 2,469
I ordered a GT-1000 CORE recently, and wound up returning it. The reason was because the jack on the side can supposedly be configured to switch your amp channels, which the GT-100 currently does with no problems. Well, it didn't quite work that way on the GT-1000. Their manual says to use a TRS cable. Well, it didn't specify if that meant TRS on BOTH ends, or TRS to TS, or what. Long story short, after two trips out to buy cables and adapters, I gave up. No matter what I plugged into it, it wouldn't switch the channels and it also had a very loud, obnoxious hum.
In the day or so that I had it, I could tell that it had some good sounds in it and lots of potential. But I also learned something else: using the software is pretty much required to dial it in unless you want to spend a ridiculous amount of time turning knobs and pushing buttons. At all times, each patch displayed every single block (24, I think), so it took a lot of scrolling back and forth. I can't speak for the full-fat GT-1000, but on the CORE version, those blocks are fairly tiny on the screen.
Even if it hadn't had the issue with the channel switching, I decided that it would be a lot of work to get it dialed in the way I wanted. I also noticed that if you look on the GC Used Gear website, there are always tons of the used CORE version for sale, and very little of the full-fat unit. That should have told me something.
Any of you have experience with this unit?
