I'm looking for some help from the technical experts here on this site reference a JMP 50 head that I acquired back in 2005 in Canada.
I purchased this unit from a pawn shop along with a 2x12 cab. Unfortunately I was unable to obtain any info on their history. At some point in time someone removed all of the tolex from both units and varnished them
The outside tags are missing and the chassis label has been modified and is vague.
I believe that the head is a 1987 lead model but I discovered a discrepancy when comparing the components to a 1987 schematic (1987 GW Unicord dated July 70). In addition I scoured the web looking for other gutshots and articles, including the Marshall 101 files.
Circuit items leading me to believe it is a 1987 Lead:
1. Split cathode resistors and caps on V1
2. 0.022 coupling caps between PI and output tubes
3. 100K FB resistor with no cathode cap on V2 as opposed to 47K FB with the V2 cap.
The biggest discrepancy is that my circuit has a 56Kohms slope resistor paired with what appears to be a 250pf cap in the tone stack circuitry. Based on all of the research I have done these should be 33Kohms and 500pf for a 1987 Lead. The parts look authentic (when compared to parts in images of other heads that I found) but it appears that these parts were added after the board was initially created. The lacquer is missing from the turrets.
The Marshall 101 document indicates that Plexis and Bass heads used a 56K resistor and 250pf cap in the tone stack and that Leads used 33K and 500pf valued parts. All of the pictures of other heads that I have found support this. Additional point of note is that the 2045 cab had professional grade JBL speakers installed on a different baffle board.
I speculate that this head was a 1987 Lead out of the factory, but was then partially modified into a Bass head (based on tone circuit modification and JBL speakers). If you zoom in on the attached image of the chassis tag you can see the words LEAD underneath the black marker cover-up. So calling out to the tech experts. Do I have a modified 1987 Lead or was this originally a Bass model? Could Marshall have changed the tone stack parts on the production line, as they do look period correct?
Additional mods:
Someone butchered the back panel and changed AC input. Screen resistors were added to the output tubes. One volume pot was removed and repaired or possibly replaced. I changed out all 3 Daly power supply caps. The bias supply is upstream of the standby switch.
Steve
Additional mods:
Steve
