Neptune
- Joined
- Mar 6, 2022
- Messages
- 8
- Reaction score
- 6
Hi guys
here's Marco with a technical question on power tubes, fuses and all that stuff.
Main character: Marshall JCM 800 50W combo (4104); I got it used in 1992, never replaced any component and, as far as I can tell after having checked it several times, it is completely stock.
Short version (for the absolute experts who need no details to grasp the nature of problems and the lazy lads who don't like to read):
- the stock T 500A fuse blew and one of the original Siemens EL34 power tubes had its glass enclosure molten and darkened in the areas above pin 2 and 3 and (to a lesser extent) in the area above pin 6 (which in EL34s is not present);
- new T 500A fuse and new pair of TAD JJs put in (plate current bias probe in series with the JJ tube placed in the socket where the previous Siemens tube failed): no reading from the probe, new fuse blown, new JJ tube with darkened glass enclosure in the area above pin 6, pin 7 and pin 8.
Need diagnosis and instructions to solve the cause of the problem.
Detailed version (for the meticulous, the curious, and those who want to spot if I made some stupid mistake and answer the post just to tell me that I made a mistake):
Weeks ago I switched the amp on and immediately noticed that it didn't sound as usual: lower volume, intermittent sound output...a bit like a car engine when half of the cylinders don't work, if the analogy sounds acceptable.
I went with the common tests to evaluate the problem (switch on/switch off, standby on/standby off, change input, roll on/roll off potentiometers...you name it) but the problem remained.
I don't think all of this took more than five minutes when I suddenly smelled a vague burning odour and I immediately switched off the amp. I let it cool down and checked it, here's the results:
So I ordered a matched pair of TAD JJs (and, while I was at it, also 1 Gold Lion and 2 JJ 12AX7 premp tubes), a plate current bias probe and a cathode current bias probe (to be used with a multimeter).
Here's how it went:
Results:
The question is simple (and, fortunately, short): any expert advice to precisely diagnose the problem and an explanation on how to eliminate the cause of the problem itself?
Thank you so much for your help (and, most of all, for your patience, if you read it all)!!!
- T 500A fuse blown;
- one of the power tubes (Siemens EL34) had the glass enclosure molten in two spots (the area above pin 2 caved in, had a dark tint and at the bottom there was a hole in the glass; the area above pin 6, which is not present in EL34s, had a milder version of the same appearance, that is to say it was slightly caved in with a dark tint)
Here's how it went:
- re-checked the original preamp tubes and all of them seemed fine so I left them in place to avoid introducing another variable to the problem;
- replaced the T 500A fuse
- replaced the power tubes with the new JJs (put the plate current bias probe in the socket in which the original Siemens tube that failed was connected)
- connected the speaker cable;
- set all pots to 0;
- connected the power cable, switched the amp on and let it warm up while in standby mode (both tubes lit up);
- switched the multimeter on, set it to mA and put the red plug in the <400mA input (as reported in the instructions);
- flipped the standby switch to get the party started but the multimeter doesn't move from 0.0/0.1, while the cones make little random, low volume popping noises.
I guessed the multimeter did not give any reading because plate current may be above 400 mA so I put the amp in standby, placed the red plug of the bias probe in the >400 mA input of the multimeter and lit the amp up again: same as before, multimeter reads 0.0/0.1 and the same noises can be heard from the cones; after less than a minute, a feeble howling sound (like low-pitched feedback) could be heard which started to ramp up in volume so after a couple of seconds I switched the amp off to prevent it to reach considerable volumes.
Results:
- new T 500A fuse blown;
- new JJ EL34 power tube (the one with the plate current bias probe in series, placed in the same socket of the Siemens tube that previously failed) has the glass enclosure darkened in the area above pin 6 (not present), pin 7 and pin 8, the JJ logo partially involved and faded as a result.
- inside the amp, everything seems to be "visually fine", that is to say there are no evident signs of burning, bloating, leaking etc.
