Rob Bergman
- Joined
- Apr 24, 2017
- Messages
- 10
- Reaction score
- 0
I did a really stupid move the other day. Was playing my JCM 800 2205 and then put it on standby after i was finished. But forgot to turn the power switch off, and left it idle on standby for 4 days.. Now its cooked. I tested the power tubes, one gets a bias reading of 44mv, the other is zero. Originally the tubes were biased at 35mv matched. The amp only has a very quiet signal now. The tubes are ok as i switched them around and get the same readings. Even tried new power tubes and there's no change. Preamp tubes were also replaced to rule out issues.
Capacitors: C3 and C7 in the signal chain were microphonic and were replaced. Still no change. Seems like the power tube reading zero is not getting bias power. Does anyone know what might cause this issue?
