Vesperado
- Joined
- May 24, 2011
- Messages
- 440
- Reaction score
- 211
**This USB mic is good for voice over work, not so much for mic'ing a cab as it colors the tone (and stutters here and there). If I get more time I will redo everything with my guitar cab mics and an ADC.**
At any rate, this is my Super Triple Super Lead amp, modified to the hilt, and set up for a "live rock'n'roll" tone. I am not reshaping the tone controls to suite recording work, I like to feel bass when I palm mute and pick hard (who doesn't?), and tbo the Marantz emphasises the bass a bit much, as well as scooping some mids and rolling some highs, but its better than my tablet's mic. It's offset from center, facing the paper cone head on, low-left spkr.
Volume is just above bedroom level at what I call basement level. It's still under house volume level, and just under "1" on the knob. 35W operation. The mids are there, you just don't hear much of them over the USB Mic. Recorded 16bit to wav.
Signal flow: Guitar > Treble Boosters > Buffer > Volume pedal > EQ > Maxon/Ibanez > Amp. See description and clips below for stomp(s) employed. You will hear me say Lo-Z because everything but the TBs get a Lo-Z signal, moreover the amp only sees Lo-Z irrespective of the stomp employed, even when dry is it Lo-Z: you are getting my live tone, no post processing, and this is how I go about it.
The Lead channel is 2204 spec. Amp is "set and forget" throughout all the following clips.
Dunlop 3mm pic > DR HT Nickle-wound 10-52 > 2008 PRS SC250 w/ MusicLily Ceramic Bridge Humbucker on full vol. in Std. tuning > CMatMods Buffer @ 12V > EB VP JR, backed off a hair > 2001 Marshall TSL-100 Lead Channel, dry > 2001 Marshall 1960A w/ stock T75 UK > Marantz MPM-2000u[sb] > USBAudioPlayerPro > Android 11R rooted w/ Magisk v24.3 > sndup.net
w/ Strange Master Clone (Throbak)
w/ GMR Spares BC Dallas (Dallas Range Master)
w/ Yamaha GE-100 Equalizer for Guitar
w/ Maxon VOP-9 Vintage Overdrive Pro
w/ Ibanez TS-9 Tube Screamer (Maxon made version)
w/ the same stomp, in mod mode
w/ GMR Spares BC Dallas on Low Cap
w/ Strange Master clone, other FET
w/ GMR Spares BC Dallas on Hi Cap
w/ Strange Master clone on first FET into Yamaha GE-100
w/ GMR Spares BC Dallas on Lo Cap into Yamaha GE-100
w/ Yamaha GE-100 into Maxon VOP-9
w/ Yamaha GE-100 into Ibanez TS-9 mod mode
w/ Yamaha GE-100 into Ibanez TS-9 stock
The Crunch Channel is spec'd off the 1959 circuit. You need a pedal to tighten up the flub...observe. All pedals are set the same as above, they were left alone. On that note, the pedals are tweeked to color the tone, not push the amp, and that's how I like 'em
Dunlop 3mm pic > DR HT Nickle-wound 10-52 > 2008 PRS SC250 w/ MusicLily Ceramic Bridge Humbucker in Std. > CMatMods Buffer @ 12V > EB VP JR, backed off a hair > 2001 Marshall TSL-100 Crunch Channel, Tone Shift engaged, dry > 2001 Marshall 1960A w/ stock T75 UK > Marantz MPM-2000u[sb] > USBAudioPlayerPro > Android 11R rooted w/ Magisk v24.3 > sndup.net
w/ Yamaha GE-100
w/ Maxon VOP-9
w/ Ibanez TS-9 in mod mode
w/ Ibanezz TS-9 stock
w/ Strange Master Clone on other FET
Enjoy!
SndUp | Post info
Record, upload, share! SndUp is a social network, for audio! We enable you to upload audio clips and share them with the world. Sharing your talent is simple!
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
w/ Yamaha GE-100
SndUp | Post info
sndup.net
w/ Maxon VOP-9
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
SndUp | Post info
sndup.net
Enjoy!
