Hi all,
I could use some help with my 5005. Its got two main problems.
1. There is a fairly loud hum when plugged in or not. It is loudest at zero volume, and the steadily drops in volume as you’re the amp up to halfway. Multiple people have reported this, but i’ve never seen a solution to it. Ive seen indications it is probably a grounding problem, but I can’t find anything unusual.
2. As I pick harder, the amp produces a very thin, harsh metallic sound on all strings… almost like a metallic slap-back. It is more pronounced on the higher strings, and it sounds a lot like fretting out due to a high fret. I tested the DI output to another amp, and the sound is still the same, so no odd speaker issue.
I have re-capped the amp, and checked all the resistor values. There are a few which seem to be out of spec, like R25 and R27, which are measuring 0.3 ohms and 0.4 ohms. All others are fairly close to what i’ve seen as spec.
Pics of the board are attached. One of the mosfets appears to have overheated somewhat. I’m wondering if it’s shot.
Any ideas as to what could be the issues? Thanks.
