Michael Inglis
- Joined
- Feb 7, 2018
- Messages
- 257
- Reaction score
- 188
The amp is a MOD102+ that i am adding a cathode lift switch to select between the stock EL84 and a 6V6. I already have that figured out. What im trying to verify is my cathode resistor and cap value. Here is the schematic with the voltages.
EDIT: I just realized i was looking at the schematic for the MOD102 not the MOD102+ so ill post the MOD102 schematic and if my numbers are right then ill know how to do it for the voltages on the MOD102+
For the EL84 i used the tube dissipation calculator and im getting 8.8 watts which seems right cause they say this amp puts out 8 watts. Here is that calculation.
Now i need to get my cathode resistor values figured out so i entered everything the same except changed the tube type to 6V6 and got the following. But would my voltages change with the 6V6? In other words would i need to take new readings with the 6V6 or would they be the same voltages as with the EL84?
I know D-Lab on you tube did a conversion on this kit to a 6V6 and then he listed it on reverb. From the pictures on reverb i can see he used a 470R resistor and when i plug those values into the calculator i get 2.8 watts which makes sense cause in D-labs listing hes saying it puts out about 3 watts. If your able to help me with this i would be VERY GREATFUL. Thanks in advance!!
