Michael Inglis
- Joined
- Feb 7, 2018
- Messages
- 204
- Reaction score
- 124
Id really appreciate some help from someone who has a better understanding of transformers than i do. I understand the basics but i want to have a better comprehension of what im doing before i start the build.
So my houses line voltage goes from 112v in the summer to about 126v in the winter and everything in between. From day to day hour to hour i never know what it will be. Ive had the electric company out 2 times and both times they give me a line about how they will surely fix it and a month later its back to the same inconsistent service. So ive been using a cheap Chinese "voltage stabilizer" that kicks on once i get around 6V above or below 120v and it corrects by about 10volts. That works ok but its not ideal.
I want to be able to choose when i boost or buck the line voltage or just leave it as it is. So im planning on building something similar to the GeoFx "Vintage Volt Adaptor" which is basically what youll see in the picture i posted. But i want to modify the purpose to boost or buck rather than have two cuts. So my understanding so far is that if i reverse the 6.3v secondary positions i will be boosting rather than bucking, correct? And to do that i had planned on using a quality dpdt switch. So there will be one switch that selects the level of boost/buck and one switch that selects whether it boosts or bucks and one switch that can bypass all that to just provide line voltage.
I already picked up a meter display that will monitor the volts, current, power/watts and freq. And i am under the impression the recommended transformer in the diagram/schematic below will suffice since the mains fuse on my DSL100HR is 4 Amps. (I checked the datasheet and it is listed as a 115v 6.3vct 4A transformer).
Originally i was sourcing my own transformer but i kept running into what seems like an inconsistentcy. Some transformers that clearly have 6.3v secondary's were being labeled as 12v center taps. Could you clarify this? Was this just a mistake on the part of whoever posted the listing? Wouldnt the center tap be more accurately labeled as whatever the secondarys are since its half of their combined total? Or am i missing something?
I can get pretty far with my own research but sometimes a little clarification can be really helpful with projects like this. Id really appreciate all the information anyone is willing to give on the subject. Thanks!
