Greenback (G12M-75 regular reissue) in a 40W 1x12 combo? *EDIT: Got an Eminence Wizard* *EDIT 2: back to a V30*
LCW
So regular G12M-75 (hz). Not the Heritage one. Thinking of getting one for my DSL40CR. Currently running a V30 which I love, but I also have a Mesa Badlander setup with a 4x12 loaded with V30s. So looking for something a bit different maybe with the DSL40CR.
Can a 25W speaker be used in a 40W combo? I use at home so don't crank it anywhere near max volume.
This one:
TonalEuphoria
USA
If you're interested in alternatives. Personally I like the quality and tone out of the Warehouse guitar speakers these days a lot more than what Celestion is doing now. But to each their own.
LCW
I got an Eminence Wizard. Local speaker shop suggested it. It’s 75W. So far seems like it’s sounding what I was wanting - vintagey, 70s ish rock (Zep) and early metal (Sabbath).
Needs to break in of course. It’s a little crispy. But the tone is there.
Im247frogs
Brooklyn, Joey!
Yup. I opted for the Guvnor but they're damn good speakers.
mallcorn
McKinney, Texas
This one:
Maybe you should consider a Celestion Alnico 90watt Cream....
Fred_Bee
I'll second that. The Creamback is a Greenback with more capacity. I have had both, and also a Redback, for an even more powerful amp, and I have found the same flavor in all three. ;)
peterplexi
This one:
My favorite speaker for Marshall now is a Celestion G12H Creamback 75. It is an amazing speaker for all things Marshall. Pete Thorn and George Metropolis will also agree FWIW!!
LCW
G12M65 Creamback.
I'm good guys. Made my choice.
Mrmadd
G12 65 WATT Creamback ALL THE WAY.
Hope I am note too lare to chime in.
Mrmadd
Word is, " Greenbacks are supposed to run in gangs or heards" of 2 but preferably 4
  • Like
Reactions: LCW
Trem man
I like the Cream Alnico 90 watt or the Creamback 65 in a combo open back amp.
Greg Rogers
This one:
This one:
I wouldn’t try that. A Scumback M75 would be perfect. Great vintage Greenback tone, but available in a few different wattages. 65w would be good for a 40 watt amp.
mspart
From the tone of the first post, I assume the combo has one speaker. I would not put the greenback in that combo. Now if the combo has 2 speakers, then the green back should only get 20 watts if in parallel with the other speaker. That is if I understand the question properly. If a one speaker combo, best to get a speaker suited to the wattage.
mspart
solarburn
Wetville
You could always run the DSL on half power(20watts)using the GB without worry. If I was going GB I'd use the 20 watt EVH greenie. Sound much better than the 25 watters do IME. Bottom end on them are excellent. The 20's take a beating. At least those in my 5153 412 have. I have over ran that cab by volume and its rated wattage threshold for many years and she takes it all. :naughty:
I just took out a V30 from my 40C and put in a Celestion Gold. The V30 has been stellar in the DSL. Made the crunch channel better compared to others I've tried. I hadn't really liked the crunch channel even boosted. It was ok with the 70/80, GB128, V series. I have an Anniversary H30 I just purchased to try in it but I got a deal on the Gold and in it went. It's rated at 50 watts so no worries. I wouldn't worry about the Anniversaries 30 watts either. I do run my DSL at a volume of 11am or noon 90% of the time at home.
The roll off from mean to clean on the Gold is rediculous. Eliminates any need for a clean channel. And the chime when cleaner...wow. I'm getting 4 more Golds for my 5150 Iconic 412. Yes...it is that good. No more reading review's on them, good or bad, wondering if spending hard earned $ is worth my time. I Fucking know hehee. :drool:
