gswearengin
- Joined
- Nov 29, 2022
- Messages
- 64
- Reaction score
- 102
Greenbacks are recommendedJust checking in, because…because.
Very happy with the Vintage Modern so far. Absolutely beautiful clean tones, and nice drive, too. I’ve found convincing super clean Jimi tones through early Slash tones. Seems like I can generally keep the master up to at least half on LDR, if not even more. Less so on HDR, but it’s safe to say this amp gives up the goods at acceptable volume levels very well.
I’ve done some comparisons between the two…the SV20 sounds great through the VM cab. It definitely has its own thing going on, but the bottom line is that there is so much overlap between them that I really can’t justify having both at this point. The fact that the 2266c cost less than the first cabinet I ordered for the SV20 is just icing on the cake.
So, the SV20H and SV112 are going back, sadly. I ordered a couple extra pilot lamps (just in case the new ones are as short-lived as the originals) as well as a power switch that lights up, we’ll see if I end up using that.
I do want to check the bias, and will also soon do some preamp tube rolling. I’m very very curious about how a pair of heritage greenbacks would do in the VM, but that’s really just because I can never leave well enough alone.
The VM really feels like it’s going to be “my” Marshall and I think this journey is hopefully complete…for now, at least.
Thanks so much to everyone for all the help, support, and suggestions along the way!
Gary
I would definitely get a new kt66 in there Pronto.Tried to set the bias today. As per usual in the world of old amps and solutions looking for problems, all is not as it seems…
One of the KT66’s has clearly separated from the base and is wiggling around pretty freely. I’ve heard of this happening, and hope it doesn’t become a recurring issue. The two bias points show vastly different readings, with the good tube at 30 and the other more like 50.
Put the amp back together and decided to call it a day. Not sure if I should use it at all at this point, but I may still try a couple things (a few more comparisons with the SV20 before I pack it up and send it back).
The amp does hum and hiss pretty loudly. Not a huge deal, or so I thought at least. Maybe it needs a cap job, but I wanted to try some preamp swapping first, and now I also want to swap the power tubes. So it goes…
Still driving myself crazy!
I found this, which is about as classic Hendrix sounding (and often playing) as it gets.
Certainly speaks in favor of the SV20 (and being able to play like a mofo…does not apply here, unfortunately).
I also found this:
Marshall SV112D16 Studio Vintage Cabinet (Black Levant/1974X Grille...
Marshall Studio Vintage Cabinet, speaker cabinet, 12" Celestion V-Type speaker, 70 watts, 16 ohms impedance, Black Levant & 1974X grille.www.musicstore.de
Which is basically a Design Store version of the SV112 cabinet with the 1974x grill cloth for a 10€ up charge. The SV212 is gone now, so this is super appealing. Better match than the 1974cx cab and I get to use the speaker I already have.
I do wish I could find a VM locally first, just so I know. But I’m definitely feeling like I can be very happy with the SV20…
mines been flickering for over a year lol
It’s just a little resistor, right…do I dare do this myself???
