Dsl40c sound has cut out a couple times and had to turn off and on to reset. Think it may be a relay somewhere. . Anyone that's had this problem and narrowed it down please let me know.
You are wrong on this or my amp tech lied to me! Not likely, read on...….My DSL head was cutting out and the problem was solved by replacing the arching JJ power tubes. The amp tech didn't replace them either, I did. He just identified the problem and I said, oh, well I have an extra set of Svetlana I will use them. Done! problem fixed.3. It is probably not a bad power tube which makes an amp cut out completely.....and there is nothing wrong in general with JJ tubes either.
sorry but your bad tube issue isn't what's causing my problemYou are wrong on this or my amp tech lied to me! Not likely, read on...….My DSL head was cutting out and the problem was solved by replacing the arching JJ power tubes. The amp tech didn't replace them either, I did. He just identified the problem and I said, oh, well I have an extra set of Svetlana I will use them. Done! problem fixed.
That’s very interesting @ampmadscientist, would you please explain the reason for connecting a cable between send and return in the effect loop? (No pedals involved)Plug a guitar cable between send and return, then re-test. Do this with no effects connected.
These are 2 of the most common causes of cut-out in guitar amps..
Couldn't find any bad solder joints after probing and inspecting everything . Guess there's no actual Tech's out there that have come across this issue so I'll have to live with it till it cuts out permanently to be able to trace it down. Thanks to those offered suggestions.
My DSL40C does exact same . It is not a tube or FX loop jack issue . I went in and checked / re-tightened all the board grounding screws . Stayed good for couple weeks . Thought I got it . Nope still doing it . It cut out again the other night .
Then a couple nights ago we had flickering power due to storms and strong winds . I was playing the amp and when the power barely flickered , the amp did the thing again . It stays on but no sound . Turn the power switch off and right back on , and sound is back . Not speaker jack or connection . Its plugged to an external 16 ohm cab . Anyone have a GOOD CLUE ?
I'm thinking RELAY related .
