Hello Guys,
I have finally acquired a full batch of nos resistors, electrolytics, capacitors to build a full amp. They all read ok on my component tester.
Now here is my dilemma :
I can't decide between to build a 1987 or to build a tube town px18 with a full 68 board which is essentially a 18 watt plexi with 2 el84.
Knowing that nos iskra resistors are becoming a pain to find wouldn't it be a waste to use them for a 18 watt plexi ?
both amps will get a 68 board.
for the px 18 i already have a heyboer transformer and an accurate copy of a radiospares outpout transformer.
if i go for the 1987 i'll have to order from marstran the complete transformers plus the choke.
Knowing that the boards are almost identical there are only 3 resistors to change would you first try the px18 and then remove the board and try it on a 1987 and then make a choice ?
my objective is to use this amp as a mod platform for an evh sound plexi : josé master volume + three in one mod.
My issue to consider is space too the 18watt will be way smaller and lighter than the 50w.
what would you do ? any advices ?
