mickeydg5
Yes I thought maybe you just stuck them in the middle there but was not sure. Still three stages up front with three stages following is a bit much too.This amp in stock form has V1B and phase inverter V2A/B on one filter node. Then the first stage V1A is alone on the last filter node. I tapped my my new 2 stages off that last node that feeds V1A.
Were you thinking I added my two new stages to that crowded middle node?
So yes, I am going to restructure that later when I order my filter caps. I will put phase inverter on its own node, then 3rd/4th stages on next node and then 1st/2nd stages on last node.
I am considering 100uF for power tubes/1st node. Then 16uF node for the screens. Maybe go 32uF for rest of the nodes.
I guess ideal would be 2 | 2 | PI for node placement as you mentioned.
