Converting a Marshall Origin 20 to Handwired JCM 800 / 2204
Ronquest
A while ago I picked up a few Origin 20s and 50s with plans to convert them into turret board builds. After getting the OR20s I found Jason Tong's video on modding the OR20 and gave that a shot for fun. Jason detailed changing the stock circuit to a JCM 800 Jake E Lee spec. Nice little mod, but I already had other plans for the donor Origins.
My goal was to use most of the stock amp parts to build an amp that can easily be modified and repaired in the future. The plan included using the head, chassis, transformers, tubes, switches and lamp, so all I would need is a turret board, pots, jacks, sockets and misc small parts.
The chassis would need a few changes, like relocating the preamp sockets,enlarging the holes for the potentiometers and adding a few standoffs. All in all, not too much and I could retain the stock face plate.
Transformers could remain in their stock locations as could all the holes for pots, jacks, power tube sockets and switches.
I did opt for a Metropoulos loop on this build, unfortunately the jacks don't line up with the stock holes and perhaps on the next build I'll remote mount the loop board or go full tube loop.
The stock amp has a Tilt control, so many things you could do with that extra pot on an 800 circuit. I decided to go with a simple gain control after the second gain stage for more control of clean to overdrive. This stage would be great for a one knob tone like in a Big Muff with a few tweaks you could easily give it a mid boost or cut with a bass / treble tilt! Maybe on the next one.
I've run this amp with the stock EL34s and 6V6s with a quick bias adjustment and both sound great.
*The stock power transformer has an offset center tap so just wire the center taps together (do not ground them) and use a bridge rectifier if you do this build.
The preamp schematic is from Mark Huss with Jason Tongs noted Jake E Lee spec changes and was mostly adhered to, so thanks to those guys.
*The voltage on the schematic are not from the Origin, but I will update it soon.
*Any additional build info will also be added here.
As with any build, there's always something I'd do different in the next build, that's the fun of it!
Hope this post helps someone.
Ronquest
I used the stock transformers, so still ~20 watts. This choice was based on implementation (already designed into the chassis) and keeping the overall cost down. The transformers could be changed and there is enough room to stuff 50 watt transformers in there or just build an Origin 50. The 50 is a larger chassis and has more room to work with, but the stock 50 transformers need shielding or lay down the output transformer to reduce coupling hum, Marshall really dropped the ball on that one and should have used a lay down PT on the 50 like the 20.
I've built both the 20 and 50, played the 20 more, but like the authority of the 50, so this confirms my personal Goldilocks preference of about 30 watts.
No power scaling, I never felt the need with this amp, but it could be implemented.
paul-e-mann
I heard you can order a Metro loop with the jacks on leads instead of board mounted so it can be adapted to any hole dimension. Next time...
Interesting project! Got any sound clips?
Ronquest
Yes, I should have gone that route. Doing that one right now with a 20 build for a customer. Always refining and always different when it comes to the next amp. I prefer a tube loop and jacks on the front panel, but space is limited and it's getting further away from Marshall normal.
Short phone recording blues, no rock/metal, sorry.
