Gene Ballzz
Hey Fine Folks,
The Simple Attenuator thread has become so lengthy that it is difficult to ascertain how many successfully completed builds there are of the fantastic @JohnH attenuator design.
I'm starting this thread with the intention of showcasing all of these great builds.
It is my sincerest request that only those with completed units reply here! I also request that any and all questions regarding these units and details surrounding them still get directed to the main
"Simple Attenuators - Design And Testing" thread, located here:
https://www.marshallforum.com/threads/simple-attenuators-design-and-testing.98285/
Of course, any likes or compliments are always welcome here!
I'll prime the pump (so to speak) with descriptions and pics of my two completed endeavors:
My first iteration of a 16 ohm M-Lite. The pics are of the earliest version, with an extra -7db stage in place of the -14db stage and no -3.5db stage. It has since been updated, but no current pics.
This next one is another 16 ohm M-Lite with a different layout, full bypass switch and a parallel option included by simply having two input jacks in parallel. You simply plug the speaker into the other input jack, set your amp to 8 ohms and set the attenuator to maximum atteuation for an overall -3.5db attenuation. It should be noted that the two "janky" stainless bolts holding the coils have since been replaced with nylon bolts, on BOTH units!
Given @JohnH advancements in design, I strongly recommend the M2 version over this (what I consider to be almost obsolete) M-Lite design, even though the M-Lite works just as well!
Thanks Folks!
Gene
Thanks Folks!
Gene
