I don't like clipping diodes in an amp. I have a JCM 900 2500 with the clipping diodes bypassed. I think the amp sounds better, and I can choose which type of pedal I would want, as far as distortion pedals. The amp actually doesn't even need a distortion pedal, even with the diodes bypassed.I have a modded marshall amp: Ceriatone Chupa/CCV variant and curious if folks prefer a boost - TS, EQ, etc - to using Jose style clipping diodes to get the amp into more higher gain territory.
The 2500 was not a good desogn. Diodes in a properly designed amp sound mich more natural than.pedals to my earsI don't like clipping diodes in an amp. I have a JCM 900 2500 with the clipping diodes bypassed. I think the amp sounds better, and I can choose which type of pedal I would want, as far as distortion pedals. The amp actually doesn't even need a distortion pedal, even with the diodes bypassed.
In general clipping diode will result in hard clipping, but using a pedal gives you the option of hard or soft clipping.
My go-to is a rack mounted 2 channel "Real Tube" preamp.I have a modded marshall amp: Ceriatone Chupa/CCV variant and curious if folks prefer a boost - TS, EQ, etc - to using Jose style clipping diodes to get the amp into more higher gain territory.
I think it might be because the diodes are driven by a tube. It depends on which JCM900 model and year you have, though. Most of the 4100 and 4500 amps have op amps driving the clipping diodes. That said, my 5215 is all solid state, with op amps driving LED’s, and you’d be hard pressed to tell it’s all solid state...... and for some reason, I don't get any kind of un-natural diode sounding gain out of it - at all. My 900 sounds completely organic and ALL unmolested Marshall, all the way.
What is "op amp" ???? My JCM900 is a 21xx series. I believe it's a '92 - I thinkI think it might be because the diodes are driven by a tube. It depends on which JCM900 model and year you have, though. Most of the 4100 and 4500 amps have op amps driving the clipping diodes. That said, my 5215 is all solid state, with op amps driving LED’s, and you’d be hard pressed to tell it’s all solid state.
I find Friedman amps to be kinda dark and to smoothish for me. Try a real Jose modded Marshall or Chupacabra if you get a chance. I really like the ERA switch Nik uses on his. It makes his amps very versatile and a blast to play.The only amp I’ve ever played with Jose style zener clipping is a Friedman BE-100. I was somewhat underwhelmed by that amp - it has occurred to me that I might have had it dialed in badly or that there was something wrong with it. But I’ve had a lot more success with pedals driving tube amps, and amps that use LEDs for clipping.
I don’t have any issues with diode clipping, as long as it’s done right. Tubes clip, and diodes clip. Tubes clip more nicely, but mixing tubes with diode clipping gets you nearly the same thing. Mixing diode clipping with JFET distortion sounds pretty nice, too. I think it has a lot to do with the gently curved transfer characteristic of tubes and JFETs, opposed to the very linear transfer characteristic of op amps and BJT stages with tons of feedback.
