V-man
- Joined
- Jan 25, 2009
- Messages
- 4,597
- Reaction score
- 3,895
Hypothetical: You have two 100W JMPs: a MV and a NMV, and you have one Captor X.
They serve your needs well with the exception of no FX loop capabilities. You have the option to save for EITHER a HW clone in 50W (your choice, MV or NMV), OR a Boss TAE, which provides an on-board loop.
The former option gives you 3 amps, (2 of which give you the Marshall flavor in 50w and 100w) with the 50W you chose being the sole FX Loop platform, all of which share the lone Captor X.
The latter option gives you only the 2 100W amps you started with, but in addition to each having a dedicated DI/IR/Load box, the TAE allows you to use the FX Loop for EITHER of the 100w amps, so you can experiment w either/both the MV and NMV varieties. The cost of the TAE pretty much = the 50W HW clone amp with FX loop added.
Taking the “backup amp for gigs” advantage off the table, which makes more sense: having an additional 50W amp, with only the 50W amp having FX loop capability and all sharing one DI unit, OR having FX loop capability for BOTH 100Ws and dedicated boxes for each?
Which do you choose and Why? If the former choice (3 amps, which variety [NMV or MV] and why).
