Warsaw
- Joined
- Jun 16, 2020
- Messages
- 24
- Reaction score
- 20
Hi, maybe was better to continue on original 18w TMB Tube town thread but i think this is a question that can be applied also on others amp circuit. If needed, I can cut/paste this into the other thread.
I built a Tube town 18w TMB and i did some mods. Playing with this amp helped me to go deep in the sound I want.
I did a cascade mod (4 gain stages instead of 3): it can be switched manually pluggin in the normal channel and with a push pull potz.
In this way the NORM channel (one gain stage) goes into TMB channel (three gain stages) becoming quite a jcm800 with a great sound.
Now I'm trying to do the same thing in a simplier way: see the schematic attached
Mission goals:
1. Have the chance plugging in TMB input to play in the 3 stages - TMB channel (a very nice "edge of breakup sound" controlled with gtr volume), switching into 4 stages for a hard rock amazing overdriven tone.
2. Switching with a footswitch.
3. When not switched, to keep the original 18w configuration, two separate channels, TMB and NORM (sometimes i need to plug in a mic to play and sing with my daughters
Config 1 (switch off) - ORIGINAL 18w TMB
TMB Input --> TMB 3 gain stages --> EQ section --> PI --> Power tubes
NORM input --> NORM 1 gain stage --> PI --> Power tubes
Config 2 (switch on) - 2203 config
TMB Input --> NORM 1 gain stage --> TMB 3 gain stages --> EQ section -->PI --> Power tubes
NORM Input --> disconnected
To achieve those results I surely need a relay switch:
Power section: from pt there are 6,3V AC with center tap for heaters, 5V AC unused, and 6,3v AC for EZ81 rectifier tube heater. One of those rectified and converted into 5V DC (like Hoffman board - this )
Switching: two DPDT 5v relay (about 1A 30V DC) controlled by the same remote footswitch. And a SPDT for when the footswitch isn't plugged in.
now the questions
Q1: There's a suggested reliable double DPDT relay (4 inputs / 8 outputs) instead of two DPDT to save room inside the chassis?
Q2: There's the risk of some popping of channel switching? How to avoid it?
Q3: Is the double switching before P.I. correct or redundant?
Q4: What's the best PT tap to use? Unused 5V AC?
Currently the amp works fine exactly like this scheme (obviously without the input switching). P.S: a couple of grid stoppers are missing in the schematic, it's only for the purpose of show the switching system.
Thanks in advance to anyone kind enough to help me
Mission goals:
now the questions
