Gene Ballzz
Great work,
though I'm not sure I like that ground lug mounted on a stand off that appears to have crushed/deformed the washer underneath it! Given the steel chassis, I think I would use a "BIG HONKIN'" soldering iron/gun to solder the ground lugs to the chassis! Permanent attachment that will NEVER become intermittent of loose! Of course, you would need to scuff/burnish the chassis surface for good flow and adhesion! I have never seen a ground to chassis connection fail on a Fender that was done in this manner! For added peace of mind, you could even use the bolt also. A good spot weld, if you have the equipment and steel lugs, could work as well.
Just My
Gene
Just My
Gene
